I went to bilal gunj at a good mechanic and had the head assembly changed since AC and gear were working fine so was the throttle body.
Changes made are as follows:
New head assembly 27k
New CAT 24k
New mounts two for 6k
Labour 5k
After all this was done the care was turning off on idling when AC was on. Tried to adjust the throttle but that wasn’t working either. Turned out there was some alterations made in the wiring. Had the computer diagnosed and fixed that issue as well (500rs).
Now apparently one last issue remains. Car is overheating even when the radiator fan is direct (all time on). Mechanic says it’s a gasket issue and will be resolved by repair. The engine is still in 8 days warranty. Should I go through the lengthy jugaru process again or just have that repaired?
