hey guys, i am planning to construct a house in islamabad in June inshaAllah. so i need to know only the labour cost for per sq ft as i am planning to get my own material.so i need some info about it.thanks
Bhai i think labour rate depends upon quality. For normal quality i think it should be under 180 per square feet. For good quality 220 to 250 per square feet.
In rwp good quality labour rate is 130-150 for structure based buildings
Sent from my GT-I9100 using Tapatalk 2
that's a little low.....are you sure? or old info ?
I think he is quoting rate only of grey structure.
Brother, Wajisfaiz rate is correct and upto dated for complete work (Grey + Finishing), my brother recently constructed house in Islamabad. Butwhy rate is also correct, he is quoting rate for only grey structure.
@jiggerzzzz
Sent from my HUAWEI G610-U20 using Tapatalk 2
I had mine done for 200.....in construction terms its called تيسی کرنڈی
Yes quoted for grey structure only. A relative's house is under construction and deal was done at 150 per square feet for grey structure only..
It's a bit off-topic, but when constructing home, make sure to use good quality electrical wires. Bad/cheap quality will save you only once but will cost you lifelong.
What about grey structure + finishing?
Already told u by me and others. Its around 200 to 250 per square feet.
Would u like to share some info with us? Like in which society u planning to build house? How many floors? Total area of land?
Well i started building my house in bahria town and its near completion now AlhamdulillahSorry for the late reply![emoji14]
Sent from my LG-F320 using PW Forums mobile app
Asalamu alaikum brother. How is your house going? I hope its constructed yet So how much did it cost you Sir? Ie per sq labor cost and construction in sq ft? Thanks
i am also going for house construction , need your updated advice ...any PM or whatss app ??
