most probably the CV joint boots are leaking - remove, clean with petrol check for looseness, if none then pack with CVJ grease and a new boot.
The little tie rod ends and rack ends can be bought new.
Check exactly what is wrong and worn - then spend money, otherwise you might end up eating daalchawal for a month. (figuratively)
