Some technical Specs:
Designation Stratos, type 828AR.0
Place and date of manufacture Turin (Italy) 1974/1975
Chassis Number from 1001 to 1008, then 1509 to 1992
Engine Ferrari Dino V6, type 829A.000. 6 cylinder V 65°. Block in cast steel, Heads in Aluminium. Two valves per cylinder, 47° included valve angle. DOHC per bank, driven by chain. Cylinders 92.5mm x 60mm, for a total of 2418 cm³. Compression ratio of 9.0 :1. Three twin-barrel carburettors, Weber 40 IDF (40mm dia.)
Max Power 190 HP DIN, Max Torque 24 mkg at 4000 RPM.
Liquid cooled.
Service every 5000 km, Oil viscosity: 10W50
Transmission FERRARI Dino, Transverse, 5-speed synchronised.
Forward ratios: 3.554 :1, 2.459 :1, 1.781 :1, 1.320 :1, 0.986 :1.
Reverse ratio: 3.3:1
Friction-disc Limited Slip Differential ZF.
Final Drive ratio: 3.82:1 (Fifth gear total ratio: 3.77:1)
Monodisc Dry Clutch Ferodo
Chassis
Monocoque design
Wheelbase : 2.18m
Front Width : 1.433m
Rear Width : 1.457m
Suspensions
Front: independent, Coil springs, telescopic dampers, Upper A-arm, Lower lever, Traction bar and Torsion bar.
Rear: independent, Coil springs, telescopic dampers, McPherson with Lower A-arm, Traction bar and Torsion bar.
Steering
Non assisted, rack and pinion, 3.2 turns lock to lock
Braking
Discs F/R, non assisted, Ventilated, with separate hydraulic circuits
Discs Front: 27.2 cm dia
Discs Rear: 27.7 cm dia
Mechanical hand brake
Wheels
Aluminium CAMPAGNOLO, 5 bolt, 14 inch diameter and 7.5 inch width
Tires : 205/70 VR 14 PIRELLI Cinturato CN36 or MICHELIN XWX radials
Body
Steel and GRP skin, made at the same time as the monocoque chassis at Bertone in Turin. Final assembly at Lancia Turin.
Front and rear hoods, doors in GRP.
Other parts : Steel
Dimensions
Length: 3.71 m Width: 1.75 m Height : 1.114 m
Empty weight: 980 kg
Weight ratio F/R : 46% / 54%
Electric circuitry
Battery 12V 60A.h.
Electrical equipement MARELLI .
Alternator 830 W MARELLI
Starter MARELLI
Spark plugs CHAMPION N60Y
Instrumentation VEGLIA
Fuel
2 reservoirs, total capacity 85 litres of Super
Consumption stated by manufacturer 10.4 l / 100 km (in fact 16 l /100 km in normal use)
Performance
Manufacturer stated Max speed. : 230 km/h
Acceleration tests:
0 to 80 km/h : 5s
0 to 100 km/h : 7s
0 to 130 km/h : 11.6s
0 to 160 km/h : 17.6s
0 to 180 km/h : 23.7s
Note : Acceleration of this car was comparable to a Suzuki 750 GT upto 140 km/h of the same age.
Gear change speeds sugested by the manufacturer: 68 km/h 2nd, 99 km/h for 3rd, 136 km/h for 4th, 183 km/h for 5th.
