Forget about focusing the LED's with LED specific projectors, the main problem will be controlling the heat produced by the LED's.
If the temperature elevates too much then the LED's will fail.I think above 300 degrees F, LED's tend to fail.
I would suggest you to do a HID projector retrofit instead.It would be far more cost effective and will be far easier to do.
LED's lighting at the moment is not yet superior to HID lighting.Take the Audi R8 for example, it has the option of LED projectors, but the stock HID projectors on it have much better output.
