Any CNG can run LPG, rather its easier with manual CNG Kits. Even you can fill your existing CNG cylinder with LPG...... you just have to buy a nozzle and go to a normal LPG seller. Few precautions are:
- LPG kits/cylinders cannot be used with CNG.
- While filling in LPG, the donor cylinder (the one with the seller) has to be placed upright otherwise slag/ rust present in the cylinder may damage your filling valve/cylinder.
- Never try to fill in LPG when there is any amount of CNG present your cylinder. You have to leak all CNG by opening pipe/valve.
- All you have to do is to adjust static running/mixture controls on your CNG kit to work with LPG.
Interesting Blend With 1-2 KG LPG remaining fill in CNG to full capacity and enjoy amazing drive ....... just like hi Octane petrol.
For any queries contact farrukh.siddique@live.com
