Liana has been reducing the Radiator coolant. Previously Head gas kit was changed but once vehicle was tested then I could still see the bubbles coming out from Radiator. Mechanic was made to do the Job again with new Head Gas kit. Soon after, he faced issues with removing Air from the system and once it was done then took the car back. This time I could not see bubbles but water busting out from the Radiator. Mechanic tried to fix that its not bubbles but something normal with Liana?s engine on normal operating temperature.
Screw it, I just want to ask Is replacing Head gas kit so difficult or there are some odds involved. I got little confused as could not see any signs of water in engine for almost two months till recently once I saw buildup of foam on engine cap.
Or what do you recommend, is this vehicle so difficult for the mechanics or should I redo the entire thing from someone else.
Also, does this Vehicle has Radiator Bleeding Valve.
