My Liana got heated.....:rolleyes: radiator empty.....gasket gone....experts plz advise.....
Closed:thumbup:
Sent from my HTC Desire S
get the head off, shaved, replace gasket, start, drive
A plug coil is short also..... Any body know the price?
Coil changed, tappet adjusted, clutch bearing replaced, throttle body cleaning pending but liana is happy to go now. Cost,3000 genuine used coil1190 clutch bearing650 head gaskit2000 labour900 gear oil300 coolent
Coolant = 300? Bro use a quality coolant like caltex,fuchs or genuine co ones. Also you should have used original gasket. Did u find out the reason for heat up ? If u didnt the condition will most likely repeat it self.
