I have Liana 2006 1.3 Rxi
Which is best engine oil for this car?110,000kms done
Also, car has a higher RPM. but sometimes it automatically drops to 600-700 but normally it stays more than 1200-1300
Thanks in advance
if its not burning oil use any 5w 30get throttle body serviced for rpm fluctuation - ask them to check tps as well
Thanks for your reply.
I have checked oil level is low. So its burning the oil.
Which one would you recommend now ?
10w40Dont go over this grade.
Hi Ehtesham,
Any special reason for 10w40?My car is burning oil. And also winter is just around the corner so should I keep using 10w40 ?
Bcz 20w50 will eventually kill your engine.
