Abdul hameed and sons near tibbet center opp rubber market very good at repairing suspension, many pakwheelrs have done repairing work from him.
Suzuki oil is also same total oil its just rebranded, for coolant go for zic pre diluted from a reliable shop. Its normal in summer for car to get hot same happened with mine too.
Complete dashboard ??
Your dads love you too much [emoji14]
That's why this car comes to you so you can realize how much your dads love you [emoji14]
When we bought the car we have spent 50k on it and I am almost in same condition as you are in but now ALLHAMDUILLAH its running fine.
Sahi hojae mera wala bhi aik dafa stuck hogaya tha thora sabar rakhain, 39 waesy sahi bata raha hai garmi hai aaj kaal.
Meray bhai ab aap 1700 wala oil dalwao ge tu that tells the story of how well is your car is being maintained. No good oil is available for 1700/4litres. All good oils in 10W 40 or less viscostiy costs 2200+. Saving 500rs mentality has ruined your car. That shows baqi cheezain be aisi tara he maintain honi hai gari ke, then don't blame car for your mistakes.
Thank you very much for this information. I really appreciate quick responses. Since now I was silent member of thread.I never did any work with my car. please guide me how can I flush radiator my self?
which pipes or clumps to be open and complete procedure for flush for Liana. I want to do myself. Should I get washed condenser from AC mechanic?
t also known with the name of perisher cap. when car got hot over flow some water in water tank when got cool send water back in radiator
drive one km after change gasket, there ll be no water.
is jaga ko chor k pura
oil me poora green coolant mil chuka hai...tou change lazmi
that was an estimate...i use zic yellow wala or zic A...original confirmed...it is 1850 for yellow dabba
live telecast from the mechanics shop....
head did not want facing..water body failed too so new one installed
went to IG motors, Suzuki 3s, first to confirm prices and my breath is still not stable to write the price of parts...
Yellow one is 20W50. Its Zic Hiflo. People use 20W50 when their engines are at last stages. After that is engine overhaul job. My advise is to stay with 10W40 at max if your engine doesnot consume oil
Suzuki use 20w 50w in liana as last time i get it changed from 3s
Hang them till death. Hang ALL OF THEM
i am using drinking wala meetha pani for radiator now...no tap water. any suggestions??
Drinking water also have minerals i think using AC water is better
minerals bring in corrosion?
Minearls get deposited on surfaces and restrict heat transfer. Some mineals can cause pitting on the surfaces...
Well got the studs+bolts for Rs 300 a pair.Kharadiya took Rs 200.Mechanic took Rs 300 for whole work because in liana whole hub assembly have to be removed else we cant get the studs out.
Give it time bro. Theek ho jaye ga.
