Did a detailed surgery of my Liana today. I had brought a brand new thermostat and ECT sensor which I needed to install. But in order to get to the thermostat housing, I had to pull off the entire intake manifold. So I took the opportunity of cleaning it as well.
Here's what I did:
1: Took the fuel injector rail off
2: Disconnected all connectors attached to the intake manifold
3: Pulled off all the pipes that were connecting air intake manifold to the engine and other areas
4: Drained the radiator completely
5: Covered the generator with a plastic sheet and then opened the thermostat housing
6: Installed the thermostat
7: Pulled the inflow and outflow heater core pipes from the firewall and connected outflow to the tap with a long pipe. Redirected the inflow to the ground using another piece of pipe and opened the tap. Clean water ran through the heater core for around 30 seconds before I turned the tap off
8: Cleaned the hell out of air intake manifold along with throttle body. Took out almost a spoon full of gunk and dirt from inside and finally dried with a power blower
9: Scrapped off the remains of old gasket and put a new gasket for air intake manifold as well as throttle body
10: Installed the air intake manifold back on the engine along with throttle body
11: Installed the brand new ECT sensor
12: Connected the heater core pipes back firmly and then filled it up with ZIC SuperA anti-freeze (pre-mixed)
13: Pulled off the overflow bottle and washed with hot water and soap until there was not a spot of dirt or gunk remaining inside
14: Filled the radiator slowly with coolant and then the overflow bottle.
15: Then washed the fuel injector rail along with each fuel injector individually with carburetor cleaner. Also installed brand new pipes for power steering bucket.
15: Then installed them back followed by a thorough cleaning of the engine with a tooth brush and vacuum cleaner.
16: Then started the engine car started up and she started beautifully with a stable idle.
17: Needle steadily rose to half way mark and as soon as it was there, the fan kicked in (YES! AUTOMATIC!!!)
I still have to bleed the air out of my cooling system since I suspect there is some air inside. Will do it tomorrow as I'm too tired now
