Hi, I hv liana 07. It showing 27 temperature on digital clock in any case.
It was working fine before ac service today. The mechanic opened the blower and fridge for service then he washed the internal portion under the dashboar (lines which were going to ac vent)with water pressure and water was coming back in a pot he place there under the dashborad . As i started the car it was showing 27 temperature. and now it is showing the same with or withour ac as i start the car.
Please suggest what can be the reason. I guess he messed up with sensor though i am not sure where is it or water could dagame it when he threw water under the dash to clean it.
Please suggest what should i check further?
P.S digital clock is showing the correct time and i parked the car under sunlight to see if temp will raise on dash clock but it is showing the same 27.
