hello i am havig problem with my liana kabhe kabhe jab start karo to self nahe leti tick tick awaz krti hai phr thori dair me start karo to self lekr start hojati hai please help me for this problems experts mane self ki service b karwali still having the same problem!
Get your battery checked
when does it happen ? in the morning or after the car has reached its operating temperature?
Check batteryGroundingSelf bushes
When your self makes tick tick noise, trying jumping it directory from the battery to check for grounding/wiring issues.
Battery is ok no subha ye problem kbhe nhe ati chalata hun phr kahin rooki phr strt ki to ye prob ati hai kabhe nhe ati kabhe ati hai bar bar self dene say speed me phr pakr leti hai self strt hojati hai
kabhe slobe me khari hoti hai to mai handbrake gira k gear dal k clutch chorta hu halka aur self deta to to pakr leti hai self aur hojati hai start
Same advise, check battery, replace if its oldet than 24 months. Check n replac self bushes. Its a cmon problem
Sent from my iPhone using Tapatalk
Liana 2008 same issueKabi start or kabi self 2 sy 3 baar tk tk , kr k phir sahi start ho jati hey
liana k self k sath bari wali relay lagwa lain... self starter ki cuppi weak hy.... us ko currnt pora mily ga to start theek homeri gari k sath b yei masla tha theek ho gai hy
my swift 2013 also started doing same recently .. it starts perefectly fine, but then sometimes for one or two times it does tick tick then third time takes the self.i was thinking battery terminal loose hain.. : (
Ignition switch gets weak and does that or starter solenoid gets bad.
Yes aur kisi din barish mein us relay mein paani jaega aur phir zaleel o khuaari alaida ho banda. Us sey better hai starter solenoid change karwa ley banda ya starter motor change karwa ley. Juggar means later on you will get khuaar and pakka kaam means replacement.
ye new mil jata hai ya bilal gunj se lena hoga ? : /
Yes dono cheezen miljati hain bilal gunj se bro.
thank you.
Relay ziada behtr aor sasti aor achi option hey na???
No very unsafe and juggari options. Always make your car reliable. Relay wala kaam is unsafe.
Liana missing kr rahi thi rainy weather mie , kyu???but automatically thek bi ho jati kuch daer bad pr tension kafi hui.Ziada accelerator press nai krny deti bnd hony lgti pr pedal sey foot release kro to ok hoti thi.Pr kafi time bad khud hi okay ho gyeFriends koi acha mashwara kisi k mind mie agr ho to please???
Relay lgwa k usko cover kr dya jae ta k contaminants / water waghaira sey safe rahy to phir janab???
Jugar jugar hy, dhoka dy sakti hy.
Maybe Ig coils are bad.
