Here are its specs !
LIFAN
MODEL 250F
LIFAN
ENGINE
air-cooled , V Twin Cylinder, Four Stroke
Displacement: 248 CC
TDI Ignition
Max. Power: 18.5 HP/ 8000 RPM
Max. Speed 65 MPH
Max. Torque : 17.5N.m/6000RPM
Electric Start
BRAKE SYSTEM
Front: Disk , hand controlled
Rear: Drum , pedal control
TRANSMISSION
5 Speed
Manual shift
TIRES
Front: 3.0-18
Rear:5.0-15
SUSPENSION
Front: Hydraulic telescoping forks
Rear: Hydraulic Spring
FUEL
Unleaded gasoline
Fuel consumption: 100 MPG
Max. Load: 330 lb
Dry Weight : 355 lb.
Colors : Red, black
