Hello people ! Can i use Liqui Molly oil in my 2007 mehran ? Liqui Molly oil with viscosity of 10w-40 api-sg or SJ ? Waiting for good response
Thanks
Why liquid moly ? They areover priced for no reason lot of api SG,sh,sj oil available in market with 20W-40
Bcoz its too good than other brands.
Currently am using SGO (Suzuki genuine oil) but noises from engine are coming.. My car is only 46000 km driven .. So want to try the best engine oil.
Since you have already made up your mind then go ahead and try the oil..........LM is a good oil no doubt about it....
LM oil is available in 10w-40 api Sg/Sj categories or not ? Plz share if someone has info.
Assalamualaikum. Liqui moly is indeed a perfect oil. Like u can run more than 7k on one oil but it is expensive. 3150 for 3 liters. If u want to go for this than best of luck. There is mobil as well. 1950 for 3 liters run 3k. Shell id useless also total and SGO and PSO. The oil i found good is Mobil.
Am usin havoline in mehran 2008. Perfect n no issue yet (ah)
How is Zic A+ for a 18k milage Mehran?
