ok, sure sir, will do as you said, I think one of the connector could still work if I can found its pair!!
Dnt u think the glow is too dull?? :S
i think u shud go for something like this
this is of my meter
No its not, as I mentioned this is a mobile cam pix,and is no way near to what the reality is.
Your meter looks cool, but Im afraid it would cause distraction and would put strain on my eyes. I feel that meters are for to see, not to glow!!
Rear seat light, I kept lots of things on rear seat, so at times its difficult to find them in dark! my bro installed a simple light on rear door for that!
This is the Metal strip protector for my amp!
Blue yar ya switch ke wiring kis tarhan connect ke hain tum nay........need help wid it cuz mare khyber main reverse switch missing hai.......
Well the switch was there in my car but it got faulty. SO we just changed it and re-attached the wires.
If your car doesn't have the entire wiring then I suggest you get it done from electrician as to me it doesn't look simple!
good job with the wiring but isnt the lamp a bit too big, cud get the lamp from the new civic and fitted a little bit inside the door so it isnt poking out, it would look as if the door was originally designed that way
Yes I agree, its actually of Suzuki Bolan, and worth just 100Rs! It serves purpose really well. But I will look for civic one as well:) I would be putting another one somewhere soon!!
Light in Glove box:)
@ night
DIY AC Pannel cleaning and Lightings!
The outcome of washing and cleaning
Blue blub fitted! It needed little adjustment to fit as the stock socket was not big enough!
B;ue glow, Now the speedometer, AC pannel and Pre all glow Blue!! look awesome!!
nicely donelike your khyber
yar can anyone tell me frm where can i get this A/C panel?????
mine has lot of scratches
bro post some pic it can be clean and repair its a simple thing (H)
awesome diy! keep it up!
scratches are in such manner that light is emitted frm them, which makes it look ugly if i add bright light
@blue how did u clean the glue ?????? surf or somthing else???
use marker n double tape
samad bond was there it was done with the help of tooth brush ,kerosene oil n thumb nail don't use any sharp object it makes scratches on it
hi, yar i own swift 85 model. the pishtashu green color one. i gave it for denting and painting. and i am going to put g15a twincam turbocharged engine from 87 gti swift sports. now, i went to the denter and saw the car. it is in the stage or rubbing and ragrai ghesai. can u guide me that how should i go for the speedo because i want it white with red niddle. as well as the ac thing which you turned to blue. i want it white too. as i am a newbie in this side so do help me out. then onething i wantto ask was should i go for pioneer 3950 or 2950 cd player. i just want a simple one in the range of 2500 to 3000. cuz spl woofer solidaudio amp and pioneer 7950 was stolen before. so i need to put something a bit simpler
