Can anyone let me know the location of all of the freeze plugs in old carb cultus ( G10 engine).
I know of one underneath intake manifold and one behind main crank pulley. are there any others?
@dani_kk @spectra @syncview @Xulfiqar @capsat
On the block and then under the camshaft inside the head.
can you point out the location of the one on the block.
welch plugs are always under intake manifold side of block.
Yes, but it's a tight fit there and not readily visible. It would be easier if I know which place to look at.Service manual doesn't mention it's location either.
sir i think G10 engine block welch plugs can not be accessed / viewed without dismantling of engine. The intake manifold is towards firewall side of car. as mentioned by sir @capsat.
you may use a endoscope camera connected with your phone to check the tight access area
send a msg on whatsapp
I can send you some picutres
Still waiting for your response
