Looking for throttle complete body of Mitsubishi Galant 2005 Model 4G63 engine 2.0l
If you mention your city/place, you'll get quick and genuine help.
City?
Gujranwala
Gujranwala brother
Brother check your local scrap yard...else you will have to go to Multan or Lahore for the thing... Also what is wrong with the current TB
Brother I am having problems with throttle sensor and idle sensor.
Have you had the car scanned for the specific codes... Throwing parts in is pointless if you don't know the exact code and the problem
Yes brother, Galant was scanned and the code is about throttle sensor. If you have any solution it will be welcome. If you see the picture of throttle, the throttle position sensor tells the story.
Firstly have the wiring checked and the position sensor to.. throttle bodies don't just go bad... What is the issue with the car? Jerks, lag, etc
@Xulfiqar sir please guide...
Sounds like service station guys drowned sensor in water, the idle motor must be bad too.
Or
Car had cng its life and the wiring has gone awry
Must have shorted out..
Idle sensor and throttle sensor are bad. During gear shifting the engine get accelerated and with the jerk but at the high speed its normal. No CNG was installed. Totally driven on Petrol.
Then try finding the sensors Bhai... Why looking for the whole unit...
Actually any thing is welcome. Sensors or throttle. Please guide if possible.
I will share a contact tomorrow brother... He might be able to help you...
Thank you
