open door card , close window glass.. now see the condition of channels, if channels loose , then try to fix it..
my Alto`s window glass also make noise , I opened door card.. after one hour inspection I came to know that the screw which holds the channel broken from frame, then simply I install one washer with 10mm bolt.. noise gone
