I found part of the problem. during engine swap two years back, mechanic told me ac bracket has 4 bolts and one is broken in block, that wont matter ,, but that broke belts in following months, replaced ac compressor but didn't solve the problem, went to Islamabad broke belt, happened twice. replaced back another rotary ac , after one month again broke belt.. today after investigation, went under car, remove power pulley, and all, found out ac bracket has 5 bolts. I got 3 broken bolts removed by welding bolts on them and fit back all 5 .. task took 7 hours due to no electric for 2 hours .. even the engine mount bolt was getting loose from vibrations, now all bolts proper tighten, fit back everything car is running much better.
