I have honda civic 2005 vti orial.The coolant in radiator slightly low and no visible leaks. Cap is recently changed. In the morning when i open the radiator cap a hissing sound comes like pressure release
What is the need to open radiator cap?
That's completely normal and again and again you are opening it and letting air molecules seep inside.
To check coolant because it decrease after a ride some time
Coolant is checked in the overflow tank under normal condition - if the overflow is completely empty or completely full then you check the radiator itself.
Otherwise leave the cap alone.
Are you using plain tap water as coolant?
No I'm using coolant
dont open the cap everyday, check the overflow tank to see its level.
