Aoa everyone,
Query #01
I had a heating guage issues with my Civic 8th generation so, I cleaned up the whole radiator. Now, the problem is the radiator lowers the fluid level after every run (almost a sip or two). I use pink colored coolant.
PS: There are no leaks as I have changed and installed the new radiator's pipes. Also, there are no bubbles showing.
Query #02
As the summers are approaching and we are going to use AC and shutting down Heater. Someone from this page said that the radiator's water would be trapped in heater's pipe and thus causing rust. Is this true? If YES, then what is the solution?
