Thanks Man!
Recommended manual transmission gear , steering and brake oils for Toyota Corolla 2007 1300 cc 2NZFE
dont be so consious about engine oils. i have driven more than 400k km on my previous car and dont remember i ever repeat same oil brand on any 2 consecutive oil changes. but make sure oil must be genuine and reputable brand. By the way other except Target and Momin, i have used almost all brands available in pakistan one after other. nothing made big difference, until you dont cross 4000km on Mineral and 5000 km on fully synthetic engine oils. i mostly used 10w-40and rarely 5w-40 in that GLI 1.3 .
currently i have 2022 Altis 1.6 X. first 2 oil changes Teglon, 5w-50 than Shell Helix ultra 5w-40 and even one change of Havoline 5w-40. found Shell helix 5w-40 best among these due to optimum cst @ 100c. despite i wanted but i do not have courage to put 5w-30 in it because my foot is heavy mostly drive 140++ km/hr. is there anybody living in central punjab and moving frequently between khi and lahore using 5w-30 in altis 1.6 with heavy foot and still not facing a problem??? i will definitely love to hear his advice.i dont agree that outside temp has nothing to do with oil viscosity, although engine temperature is very high but dissipation of heat in hot weather and cold weather very different and that time to dissipate heat has effect on engine health and load on engine oil.
I did that for 70k kms without issue. 5w30 Castrol magnetic. Drain interval 10k kms. Local 12.5 kml, long 15kml at 120, 13+ at 140+
hi... dear plz guide if u r satisfied with Delo gear oil or not? if i have to choose between delo and kixx which is better?for mehran 2017 model
Suggest me best engine oil for Suzuki Alto 1000ccModel 2010Km driven 71350
in an years time over PW i have realized that engine oil specs for an ICE engine shall never exceed 10W-40 Best shall be 5W-30 petrol & diesel engines or 0W-20 (for hybrid engines). The lube oil table in owner's manual mention the temp range for the engine oil depending on area of operations.
10w-40 from any genuine brand. Zic, shell, caltexRecently i purchased Aisin engine oil and so far so good. I have been using their coolant, superb quality.Anything you buy, must be from authorized dealership.
0w-20 is not only for hybrids... Depends opon the engine
Suggest best engine oil for Suzuki alto 1000ccModel 2010km driven 71350
5w-30 engine oil (choose brand carefully) is best for any PKDM or JDM vehicle
Which engine oil is best for Toyota Corolla Grande 2016 110k driven. Shell 10w-40 yellow one or 5w-30 blue one?
10W30 synthetic of any brand
5w-30 fully synthetic
AOA, I recently bought a Toyota Grande 1.8 2014 model its 93000 km done I didn't know about the last gear oil change, I asked the price from the dealership its costs around 20000 but they said they would not change the gear oil because my car has run over millage so it can create an issue when u change a CVT oil after over mileage so should I change it from outside local mechanic and can someone suggest me good mechanic in Karachi who can perform it with OEM standards?
I'm not an expert but i know changing the ATF on a transmission that has alot of mileage and no oil change history is a gamble. It could lead to problems like slipping,etc. Try getting in touch with the previous owner and ask him about maintenance history (always buy a car with verifiable maintenance history)@Xulfiqar can guide you better
So what should i do, like i donot have any contact of previous owner, and i am sure they never change cvt oil, so what should i do now ? Isi trah chlata rha ya change krwau? Or after changing oil koi issues aty hain to wo kia ho skty hain?
Yes better to get it done from outside and the cvt fe oil costs 9500 from wholesale market which is around 12k in local market and 20k on toyota dealership.
Can you recommend me any reliable shop or online store from where i can buy cvt fe and any good mechanic who can change it with oem standard method in Karachi?
