I already linked mobil1 5w30 above that says acea a5/B5 on the box. Get that one available locally. Triple action power mentioned on can.
For liqui moly there are different variants, which one are you referring to. Attach can pic.
Basically oil that is rated B4 or B5 will work fine in your revo, as per its owners manual. These are European standard oils.
Other standard is API where it should be above API CF4 as per owners manual. Latest is API CK4.
