Reply any one please
I have santro 44 k driven which engine oil should be used in it .presently I am using caltex 20 w 50.because i got some engine work done like new rings new engine valves etc.plz recomend.
U r using best oilCaltex havoline 20-50 or 10-30 both suit u
Sent from my LT29i using PW Forums mobile app
Ive recently bought 72k driven city idsi 2007. Previous owner was using shell helix hx5 10w-40 synthetic motor oil. I read synthetic oil isnt good for old engines n ive 7 years old one. Kindly advice i should use which oil n why? Or continue previous
where can one buy Genuine Caltex oils From in Peshawar ?
0W-30 is not suitable for Karachi.10-30 is better20-50 is best
sources?
Hmm an answer without any research on grades and viscosity and effect of temprature on both of themInteresting
Source is the classification of oil in grades. The “W” in Engine oil grade stands for “winter” and indicates that the oil meets certain viscosity requirements for low temperature. The lower the number before the “W,” the better the oil works in cold weather. The temperature of Karachi is moderate, so why pay more and use 0W-30 if 10W-30 or 20W-50 works??????
Iam using shell helix hx5 in swift mehran and cowrolla 2007 is this oil worth to buy
Sent from my SHV-E160S using PW Forums mobile app
Please take a moment to familiarise yourself with the following, http://www.kewengineering.co.uk/Autooils/oil_viscosity_explained.htm#_Toc240461895
Thank you
If you care normal for your car, change it:
5000 KM/ 6 Months - Which ever comes first.
If you are Very concerned, then change it:
3000 KM/ 4 Months - Which ever comes first.
There a new but very credential company in the market now named as "Petronas". try using its products.
Its a Malaysian State Oil Company https://www.pli-petronas.com/about/about-pli
Mach - 5 range in Different Grades is available in the Market throughout pakistan.
SM being the highest and SF being the lowest Garde in Mach 5 range.
Yes. Very nicely described oil changing intevals.
If you are very concerned about your car, spend your money on scheduled maintenance items, instead of throwing it away on 3k km intervals.
Even 5k km is a very conservative OCI.
hello dear, i own a Honda City 2007 driven 150,000 kms used to have CNG too but got it removed around 5 months back and driven last 10,000 kms on petrol only. Which oil do you recommend me to use.
I normally use Shell but I have heard that Total Quartz 9000 is the best lubricant. Pls suggest me the best match for my car.
Aoa frnds plz tell me ne shell semi synthatic 10w40 oil dalwaya tha city 2002 me ye oil kitny arsay tak chal sakta hy 1 year or 3000 kms which ever comes first ??
I have found that AIMOL lubricants has a very vast range for vehicles, Industries and Food grade. AIMOL is no doubt the best choice for all vehicles in Pakistan. Aimol also has approvals from hi end car manufacturers like Mercedes Benz, BMW, AUDI etc.
Guys, I have compiled the viscosities of few engine oils. As u can see, viscosity differ from brand to brand even with the same grade oil. So choose wisely.
E.g. 10W40 or 5W30 of one brand may not be as viscose or thin as another brand with "same" grade.
Also, viscosity of "same" grade oils will differ if one is mineral and other is synthetic.
