That is a "Check Engine" llight, take it to a workshop, they will connect an OBD scanner and read fault codes, then they will fix the iisue according to code. It could be any connector lose or just cleaning of sensors, they might just also check/clean fuel injectors, spark plug, fuel pump, ignition coil, O2, CatCon, air filter etc.
