Powersports Model Comparison Tool
Honda CBR 1000RR
ENGINE
Engine Type 998cc liquid-cooled inline four-cylinder
Bore and Stroke 75mm x 56.5mm
Compression Ratio 12.2:1
Valve Train DOHC; four valves per cylinder
Carburetion Dual Stage Fuel Injection (DSFI)
Ignition Computer-controlled digital transistorized with three-dimensional mapping
DRIVE TRAIN
Transmission Cassette-type, close-ratio six-speed
Final Drive #530 O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension 43mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability; 4.7-inch travel
Rear Suspension HMAS Pro-Link single shock with spring-preload, rebound and compression-damping adjustability; 5.3-inch travel
Front Brakes Dual full-floating 320mm discs with four-piston radial-mounted calipers
Rear Brake Single 220mm disc with single-piston caliper
Front Tire 120/70ZR-17 radial
Rear Tire 190/50ZR-17 radial
DIMENSIONS
Rake 23.45 degrees
Trail 100mm (3.9 inches)
Wheelbase 55.2 inches
Seat Height 32.3 inches
Dry Weight 388 pounds
Fuel Capacity 4.8 gallons, including 1.06-gallon reserve
OTHER
Emissions Meets current CARB and EPA standards. California version differs slightly due to emissions standards.
Available Colors Light Silver Metallic, Red/Black, Black/Metallic Gray, Blue/Orange/White/Red
Model ID CBR10RR
FACTORY WARRANTY INFORMATION
1 year Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan
Honda CBR 600RR
ENGINE
Engine Type 599cc liquid-cooled inline four-cylinder
Bore and Stroke 67mm x 42.5mm
DRIVE TRAIN
Transmission Close-ratio six-speed
Final Drive #525 O-ring-sealed chain
Front Suspension 41mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability; 4.7 inches travel
Rear Suspension Unit Pro-Link HMAS single shock with spring preload, rebound and compression damping adjustability; 5.1 inches travel
Front Brakes Dual radial-mounted four-piston calipers with 310mm discs
Rear Tire 180/55ZR-17 radial
DIMENSIONS
Rake 23.7 degrees
Trail 96.3mm (3.8 inches)
Wheelbase TBD
Dry Weight 345 pounds
Fuel Capacity 4.8 gallons, including 0.9-gallon reserve
OTHER
Available Colors Black, Pearl White/Silver, Red/Black, Ultra Blue Metallic/Silver
Model ID CBR600RR
1 year Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
Honda CBR 1000RR 2007
Honda CBR 600RR 2007
Note:- 400cc Is Closed By Honda Company .
