forgot to attach your reply...
[IMG]https://www.pakwheels.com/forums/images/misc/quote_icon.png[/IMG] Originally Posted by Navqam <a href='https://www.pakwheels.com/forums/mechanical-electrical/153379-maintaining-ups-car-batteries-post4872549#post4872549'>[IMG]https://www.pakwheels.com/forums/images/buttons/viewpost-right.png[/IMG]</a>
Dear Talha Bro,
This is Naveed from Rawalpindi. My dear, i am facing some UPS & Battery issue and am sure you can help me out. Presently i have one local "Sun Power" UPS 1000 VA (for 3 fans and 6 E/Savers). Battery installed is AGS GR-165. Two days back the battery went "OFF" dead after 40 minutes backup for 1 fan and 1 E/Saver. It took around 1 complete day to charge again. On next use, it never provided one minute back up. I took the battery (which is 13 months old now) to the dealer, who removed the caps, checked its gravity, on the last cell he told me that the cell is GONE and battery is useless now. He proved it by short circuiting + & - of the battery. A boil was created in that specific cell, even fumes were coming out.
He told me that battery needs to be replaced, and UPS needs to be checked. May be it is overcharging (battery was never noticed swelled) and for many other issues.
Please advise me what to do. My total load for UPS is 3 fans and 6 E/Savers. Please tell me the brand / Specs of UPS & Battery to purchase. An early reply is requested please.
Best regards.
Important Note: Please note that AC Volts (Electricity) from IESCO received varies between 190-200 Volts. In this situation which UPS suits; Local or Homage/Inverex/Luminous type?
[I]Thing is that, you need to verify the charging rate on this UPS, if dealer is saying that battery is gone then I believe that he is telling you the right thing as you just verified that it gave a backup time of one minute. Once, things boils down to one minute then I guess, condition of the battery will be very bad and beyond recovery. Battery can only be recovered, if you detect a problem earlier and before a damage has taken place.
I believe, that you got an imported UPS and most of the imported UPS trickles charges the battery starting from 10 Amperes which you are expected to verify using multimeter along with the cut off voltages. Since, battery installed was AGS GR-165 so that tells me that its amp-hr rating must be grater then 100 AH so UPS setting is not an issue here.
You problem was a bad electrolyte, next time try to buy a phoenix UGS series without their electrolyte and buy the electrolyte from pryo chemicals.
Whenever you use a bad electrolyte then one experiences the same results as you have quoted. Secondly, most of the battery water (de-ionized water) available in market is a fraud. Check the main thread for TDS values of brands which you can buy. TDS value of battery water should be between 0-10. AGS tonic is a good product.
sorry, that was a premature failure. [/I]
<a href='https://www.pakwheels.com/forums/newreply.php?do=newreply&p=4873116&noquote=1'>[IMG]https://www.pakwheels.com/forums/clear.gif[/IMG] Reply</a> <a href='https://www.pakwheels.com/forums/newreply.php?do=newreply&p=4873116'>[IMG]https://www.pakwheels.com/forums/clear.gif[/IMG] Reply With Quote</a> <a href='https://www.pakwheels.com/forums/newreply.php?do=newreply&p=4873116'>[IMG]https://www.pakwheels.com/forums/images/buttons/multiquote_40b.png[/IMG]</a> <a href='https://www.pakwheels.com/forums/report.php?p=4873116'></a>
