@Ishtiaq778 @talhawaleed
1) I tried to adjust the Battery Low on the above kit and the highest setting I could set was 19.65V, I can't go higher than this as the variable doesn't allow to twist any further, can only go lower. Is this normal for this Imran Brothers kit or the variable is faulty?
2) Secondly I noticed that after draining the batteries to 19.65V the battery attached to the negative terminal showed 9V whereas the battery attached to the positive terminal still showed around 11V. Is this a sign of bad battery? They are only a year old with Pyro Electrolyte in them and pyro distilled water being used for top-up since the start. And UPS tuned as per the instructions I read/got from this thread.
P.S
Batteries in question are Phoenix UGS 175, charging rate is set at 17A and cut-off is 28.20V.
