@ishtiaq778
Thanks for the reply, got a few more questions bro hope you answer them.
1) By mistake I messed around with the Main Low variable, will this mistake effect how the UPS charges the batteries and will this be harmful if I don't adjust it back to it's original setting? Can you guide me how to adjust it to it's default or optimal setting?
2) Is is better or worse to increase the cutoff voltage from 28.15V to let's say 28.25 or 28.40 as you have mentioned? How will this effect the life of the batteries?
3) I noticed that sometimes when batteries are full, the Battery Full light on my UPS turns green and stays solid but at times when it get's full the green light comes on and off (blinks) every second. Is this normal behavior or indicates some fault in UPS?
Thanks in advance.
