Just now I have talked with Him. He said. It is ups problem and this is not a cut off problem. Other amperage problem which cannot be set or changed.
Even if u put another new battery. Ups will destroy it in 6 months or early this time.
Tell me how long did the UPS center check your ups? I mean did they say come tomorrow or checked it within 1 hour.
Another Problem is battery guy checked your battery and said its fine. Ups guys said the same. Now who to blame ? If u r smart. It's ups company to blame.
I can tell who is doing what on phone not here.
Problem is in your ups which cannot be fixed due to its design flaw which is intentionally not fixed because all company needs ups is to get through warranty period and then company says its not our responsibility now.
The brother i talked with. His ups if maintained well works for 5-10 years and is reparable anytime if not maintained by customer or if a crisis of electricity causing it to breakdown after all safety features die. Still reparable.
But inverters are not reparable after 2-3 times because the sheet used is thin.
All i mean is company products are not high quality unlike Apple products.
All a company cares is a product passing its warranty period.
Inverters over charge sometimes causing battery damage
Inverters charge well only if exact 220 volts are given. If less or more they slow charge or over charge or other problem.
At your homes volts may drop or increase. But when we take a broken inverter to companies. On their service station they have exact 220 volts there. And ups works fine. So they blame your battery then.
Apnay paroun per paani koi nhn aanay deta. This is the problem. Because no proper quality standard laws here. Laws hi nahin hen implement tu baad ki baat hei.
Good luck
If u are in lahore only then buy from this guy for ur next ups or recommending any friend and seeing urself its result. I swear u won't regret.
How many times u used to refill battery water?
