I asked Abid about your issue. He said UPS MEI FAULT HEI. Usko agar warranty hei tu check krwayein. Warna jis trah se woh 4 months mein issue de rha hei tu battery mei bhi masla kr chuka hei.
Company waloun ko dikhayein tu woh OK keh kr battery per ilzam lagayein gay. Apnay paroun per paani koi nhn parnay daita.
Old ups is fixable but u will have to send to Abid to get a good fix about it. Desi ups is repairable and customizeable as much as possible as many times as possible. Not the inverters. Aik do baar repair krnay ke baad unki kit hi kharaab ho jaati hei. Which sometimes even companies dont fix or make.
He says keh agar waqai inverter ka masla hei tu koi jugaar laga kr chala sktay hen if company doesnt fix or says its ok and blames battery. But jugaar phir jugaar hotay hen. Kitnay arsay tak chalein gay. Another problem a jayay ga. Phir koi aur.
Battery ka backup kesa hei??
He said keh itni bari full sized battery ke liyay bhi 17 amp kam hi hen.
Aur jab charging kr chuka ho. Tab check kijiyay ga amp meter se keh tab bhi halki si charging tu nhn ho rhi!?
He also asked me keh " yeh bhi nhn pata woh amp meter halkay wala use kr rhay hen ya achay wala. ".
He said keh battery jab 4-5 ghantay charge ho rhi ho tab haath laga kr check krein side per kahin garam tu nhn ? Neem garam se zyada garam hogi. If yes, then you battery has been damaged.
