Hello Talha Bhai, I checked the readings on the battery terminals after charging the battery for approximately 4 hours I turned off the inverter and removed all connection cables and took a reading on 200AH battery terminals which was 13.17 V and after one hour readings was 12.90V (note there was no load on the battery, as all the cables were removed) after one more hour reading was 12.46V and after 28 hours reading was 12.36V. My question is that why readings are automatically dropping on the battery terminals when there is no load? As inverter was also disconnected from the battery. I also checked the internal voltages of individual cells using a procedure like connecting the positive probe of the multi-meter with positive terminal of the battery and then submerging the negative probe of the meter into electrolyte of individual cell, one by one. Readings were as following;
Cell no 1= 1.98V, Cell no2= 4.17V, cellno3= 6.33V, cellno4=8.48V, cell no 5=10.62V, cell no 6=12.76V. To make sure I took readings three times.
After one hour readings were like this( all cables from battery were removed as well as inverter); cell no 1= 1.92V, cellno2= 3.99V, cell no3=6.06, cell no 4=8.13, cell no 5=10.19V, cell no 6= 12.26V.
I also noticed one thing that if battery is full and I only run 23Watts load on inverter for one hour inverter takes 2 to 3 hours to charge the battery before terminating the charging and some times it does not terminates charging at all.
