This normally happens once we pour the electrolyte in battery for first time as seller must have over filled the battery or electrolyte which is absorbed in plates initially must be coming out and mixing with one in battery. During charging, plates get rids of sulfuric acid which mixes back with original electrolyte and during discharging it absorbs the sulfuric acid again. So this process goes over and over again. Just adjust the level of electrolyte in battery according to its indicated mark by removing excess using hydrometer. Nothing to get worried about and manufacturing date is ok.
Secondly, you need to adjust the charging rate and cut of voltage to 28Volts once charging should stop. Since maximum AMP-HR rating of these battery wonât be more than 100 AMP-HR as your battery is AGS GR-100 so correct charging rate should be 5-6 amperes maximum.
Do the first yourself and supervise the second by taking help from UPS guy.
