Also got these enquiries bro, hope you can clear things for me as you seem to be quite knowledgeable, so I'll ask you a few questions, hopefully you will share your knowledge.
#1 What's the approx wattage of a ceiling fan???
#2 And as I've mentioned my requirements, how much load in WATTS do you think I'll put on the UPS with " 4 ceiling fans, 1 small side fan, 4-6 23W energy savers, 2-3 tube lights, 1 old style Sony TV and 1 PTCL internet modem."???
#3 My UPS is currently charging batteries initially at 12-13A, is this fine and safe??? What advantage or disadvantage of increasing or decreasing this setting???
#4 My UPS is currently outputting 270-280V when on battery use and batteries last only 1 hour, if I reduce this setting to let's say 250-260V output, would that provide a longer battery time???
#5 My UPS is currently cutoff at 14.30V, if I increase or decrease this setting what benefit/disadvantage would it do???
#6 The two batteries I'm currently using used to give 1.5 hours of backup, recently after a 2 hours loadshedding and draining of batteries, the backup is hardly 45 mins. I've checked the electrolyte level and it is fine, and I've checked the voltages and it cutoff at 28.30-28.60V and after a while one battery is stable at 12.60V and the other at 12.38V. And during the last few minutes of backup I've checked both batteries show above 11V but the fans speed too slow, signalling battery juice run out and output shows only 200-210V. So what could be the issue here??? Do I need to ask the battery wala to charge the batteries fully??? They charge 300Rs for this service as you might know.
Thanks a lot!
