After going through various posts here on pakwheels, i finally decided to go for work that was pending on my Mehran 98... BUT it proved very "COSTLY":o... knowing mehran is least expensive car to maintain.:S
Both Axles were giving clacking sound on turning & also at times while driving straight. Bearing on both front wheels were also damaged. Brakes was also not good enough..
I made my car inspected at 3 axle shops.
First at nazeer engineering works at lucky star as recommended by Xulfiqar, he quotes 6500 for replacement of axle, steering rod (kabli) and installation of bearing (bearing has to be provided by me).
Second at axle shop near plaza he quotes 6000 for same work.
Finally at shahjee saddar quotes 4000 for same. looking on less cost I decided to do axle work from there.
shahjee apparently changed:
Both Axle kabli (3 month warranty)
Khainchi bush
Balance rod bush
Repaired:
Steering rod
Ball joint
Reckend
Tie rod
& Installation of bearing.
Same day after axle work i felt tire was not moving freely... I showed this to shahjee he told it will get free in 2-3 days, but i had feeling that something was not right, next day I took car to my mechanic he informed that brake is not loosing tyre grip. He also informed that axle seals are leaked & steering screw was slipped free (inside bonnet). Mechanic did the brake work, changed all tyres brake show, pad and pipe also installed bearing on back wheel. I took car again to shahjee next day he (apparently) changed seal and fixed the steering screw moreover apologized for the mistake.
The following are cost breakup:
Bearing Naachi (2 front wheels) 1300
Axle work 4000
Petrol switch installed inside bonnet (landi renzo) 1000
Self work (garraee broken) 700
Brake accessories (2<sup>nd</sup> grade) 1500
Wheel bearing china 250
Mazdoori (brake work & others) 500
TOTAL COST 9250
Can anyone answer following?
Still wheel alignment/balancing and tuning have to be done…….:-# How much it cost?
How long all these work last????:S
Is this normal for car like mehran to be this much expensive??
