Getting ready for the job - picture doesnt show my chair
my trustworthy companion (Proxxon industrial)
Heres where you apply the special caliper grease
anti squeal spray
sprayed to back of pads
install shim (this car uses 2 shims per pad) and grease between the shims.
The brake piston is pushed in by the C clamp - its self explanatory, just wedge a used pad on the piston, install clamp and tighten till flush (be sure to suck some fluid from the brake bottle on the MC - it will overflow when the fluid is pushed back.
Before going for a drive - very very gently stroke the brake pedal (10-12mm strokes) till you feel the pedal become hard and solid - You are seating the calipers back onto the pads.
I didnt show the removal process, its the same drill - easy peasy
