[I]^ What is the difference between 2nd and 3rd gen?
Also as you know about A series a lot do you have any idea ECU No 89661-1A120 is designed for which generation?[/I]
@Vaqas1
firstly the ECU 89661-1A120
was manufatured from
<table class="table"><tbody><tr valign="top"><td>
</td> <td>
</td> <td>
</td> <td>05.1993 - 05.1995
meaning that this ECU is from a second generation AE100 (5A-FE) M/T
<table class="table"><tbody><tr><td>identification code
</td> <td>AE100 -0049714</td> <td>PLANT.A31</td></tr></tbody></table>(made in the TOYOTA CITY PLANT)
secondly the main differences in the 3rd generation were the newly redesigned intake manifold which promoted more mid-range torque than High-rpm power because of the elongated and somewhat restrictive runners and a changed plenum, this lead to a lower requirement of fuel in the RPM range so the Nippon Denso yellow 2nd gen (fat) injectors 176cc/min were replaced with the (thin) 3rd gen injectors Grey 155cc/min, this promted for a new ECU and a new ECU map(which sacrificed high rpm fuelling for midrange torque) and the rev-limit was also lowered furthermore the exhaust manifold was also changed with a slightly less restrictive tubular on and the downpipe was also reconfigured...........small but nonetheless noticable changes.
thank you.
