AOA guys, recently my margalla's horn has started acting up,
it generally doesn't feel as loud as it should be.
it sometimes stops working, usually when both the headlights and ac are on
sometimes it won't work when the steering wheel is turned
i tested the wires for one of the horns with the multimeter, i connected one probe to the battery positive and the other at the points where the wires plug in, one terminal showed 0.50 volt and the other terminal of the horn showed 11.5 ish volts, this was with everything off.
i am concerned that it should be zero volts at one terminal and 12.9 (battery voltage) at the other, is this normal
