Possibly Leak Injectors Causing It Running Extra Rich Making Black Deposit On Plug Causing Missing And Unburnt Petrol Smell From Exhaust....
It Happens Till ECU Is In Open Loop And Running Independent..
Once It Hits The Close Loop And Started To Depend On Other Sensors Then Fuel Got Adjusted Taking Readings from Other Sensors.....!!
Agreed With Xulfiqar.....!! Also Make Sure You Water Temp Sensor For ECU Is Working Too....!!
