Hey Guys, I hope you are doing well. I recently swapped a 2GR in my Rx8 and now trying to make the AC work.the AC lines and everything are done just the AC compressor needs the wiring, but unfortunately no one knows how to wire it. Its a Mark X / Crown AC compressor with 6 pin connector on it.I have been searching through the net for a while but couldn't find the AC compressor wiring diagram.I have also reached out to a lot of AC workshops in Karachi but no one knows how to wire it.If anyone can share there expertise on this I would really appreciate that.Thanks
traction control works?pretty much a widow maker setup ! i had a crown with 2GR it was crazy
are you in karachi ? @brownrose78
In Karachi, Bashir Autos or M.S Autos in Tariq Road can be consulted for this
You need can Controller to operate the own Compressor else swap the compressor with 4-3 gr clutch based compressor
You'll be better off using a simple clutch compressor - while this compressor can be made to run as well, you need some components and lot of wiring inside and out to make it work properly. In Lahore, I can do that job, no idea about Karachi,
