Salam, this is my first post on pakwheels forum although I do read many forums but anyways I bought a mark x 250g(whose whole body is showered) recently after some time I had a bit of issue with abs the abs check light turned on after driving about 50 kms or so and of course because of check light the abs didnt worked so I went to a workshop( im from a small city called gujrat with limited mechanics and expertise) the mechanic told me that all of its wiring is aftermarket hence the ode scanner couldnt diagnose the error I tried almost all of shops in my city none of them could come up with a solution some said it was due to faulty abs unit, some said it was due to abs master cylinder and some said it was due to wiring etc so I need some expert advise on where can I get my car 100% proper and it also has some water leakage from driver side pillar and above accelerator during rain and after washing my car. So please recommend me a good workshop in area of lahore which can solve all of my problems,
regards;
Hamza
