Generator light in dashboard seems very dim from few days, it was fine and clear like break and oil light few days ago.it turned off normally after car start.
is there any problem???Causes and rectification???how it can b fix???
firstly check and remove the bulb itself, if its ok - then the V regulator in the generator is packing its suitcases.
change bulb
salam i know how to fix ur prob .u do nt need to change the bulb and other stuff if the dim battery light is showing in the meter while engine is runing u must check the generator cutout of light in the generator u cn easily change the electric light cutout for 400 to 500 rupees thn the battery light will not be shown
