hi.plzz tell me which engine oil is best for weak engine mehran 2006 model.and if a change the engine rings will my engine works good or not?
20w-50 will be good for the engine.
Compression test can ascertain the work required. under 150 psi value at wet test means overhaul is needed
From where in lahore a compression test can be done ? And what would be its cost?
0321 4106898 Obama Car & Truck centre located in Tee Poo block, visit By appointment only
