Overhauling cost depends on your engine condition. If your car's head assembly is damaged then you will have to replace it. Also, you will need to rebore your piston cylinders if there is a large play in the pistons. Also, you will have to polish the crank and change the oil pump. I have recently overhauled my Mehran's engine and it cost me around 45K inclusive of labour cost.
