guys my car gears get stuck.. it's mainly 2nd and reverse gear which seems to stuck forever , don't engage easily .. i hv to neutral it and move the gear stick left right many times and use the force then it works with grinding sound... 3rd and 4th gears are smooth... i hv got it checked, some says its clutch plate issue some says its pressure plate is weak... however the pick of car is fine... is this problem related to pressure plate?
Sent from Mars using Telegraph
