@ ekdrifter, Yar, tell me the cost of replacing of wishbones and axles (both right and left). both the prices of genuine and Chinese ones. can i use Chinese as compared to genuine? will it be worth it?
Bolan Vans have 3 leaves on each rear wheel and Mehran one, go to a suzuki dealership and look under the cars.
agreed with xulfiqar ... FF mehran has one leaf spring .. ppl love to add more and makes it really hard ...
There are three kinds of silicon cans which one is to be used to lubricate the kamani bushes.Silicon spray,grease or sealant.
No offence to xulfiqar but my mehro also has 3 leaf springs.
Sir first of all it reduces oil then Weak rings plus valve seals can be problem as its reducing oil and on start up too much blue smokeand Check what digitalmohsin suggested plus try first to rotate the sensor its near carb my mehc broke it and it wasn't showing any reading but an turned on at 50% and new one i got had an error also it showed 10% less then what actual reading was
Chimtay kaubli ones in tip top condition 800 for both and will last for 2 years in rough driving axels 2500-3000 kabuli but mostly it isn't proper fit but i say change both staright and CV joint danda wohi rehne dou will be needing to chnge the cross and staright kuppa cost like 500 for cross and 300 for kuppa 1 piece and Cv joint new chinese with 8 months warranty is 1100 a side and do take care of one thing never let kharadiya extend or short the original length of axels
simple grease will do good no spray can get between kamanies
i think u don't Get mehran in TEXAS :oyar i think ur confused yes a single kamani on each side consists of 3 layers of Leaf springs that's the best way i can put it and yes i have visited many 3s dealerships and all mehrans come with 3 layers each sidemy cuzin has a 98 bought 2nd hand and it has 3 layers on each sidesand he owns a 2007 mehroo bought brand new the car is very much original nothing replaced or modified its still in the condition which a new mehran is and it also has 3 layers on each side mine had 3layers on each side it was a 2002 and i never added any thing my friend did a stupid drop on his mehroo its a 96 and he took 2 layers out and left with single one and his car is a pain to drive over speed bumps beside only a single person sitting makes his car go mad
what do you mean? adding layers makes suspension soft or hard? my mehran has only one layer.
Mehran has only signle leaf in rear suspension, if u add multiple layers the comfort and joy to drive is gone...Zulfiqar bhai is right...as always...
adding layers makes it like a truck too hard and it consists of 3 set of leaf springs each one large wich connects to body and 2nd one is smaller and 3rd one adds a little stiffens which is OEM
Single kamani with 3 leaf springs
I am feeling that idle engine sound of my mehran 2010, 62K approx driven, is bit increased. What should I do as routine maintenance to decrease this sound. Till now I am using ZIC A+ 5W/20 and car is not decreasing engine oil.
you have just pointed out the mounting points of the leaf spring, you cant even see layers..
The old 800 FX even had one leaf spring. Three leaves are in Vans and pickups.
@ekdriftr, i have a gut feeling, Xulfiqar bhae is correct, as Petrol variants have one, maybe CNG variants have more then one
I've two mehrans both FF CNG both have 3 leaves one main that attached to the body and rest two are smaller.
Actually this might be the case. As I own a 2006 VX CNG and it got 3 on each side. We had another 2003 model and that too had 3 on each side.
CDI Installed new starting self of toyota corolla diesel(according to the electrician)
