dua cultus mehran nhi dekhti
@ekdrifter
This is the current situation of oil after using it for 2500km, the oil is ZIC A 10W40 and was poured in on 12th of june 2014 and still it is clean and ek is the level ok? I usually drain it at 3000km
Sab theak hai biru Ik dam okay hai
Sent from my GT-I9300 using Tapatalk
I have a question :About My mehran's euro 2 vxr speedo meterWhen i start driving from 0 the speedo needle wont start up or cross "0" position until car's goes more than 20 kmph speed?Is it normal
Go to electricition and open meter use oil or grease at the place where speedo wire connets to needle
I have 2 problems in my mehran 2005 1. When i relese the cluch a tuk sound is produce i have changed all front bushes along with the both chimtay but the problem still exists since 4 to 5 years
clutch might cause this sound if u changed bushes etc2 get it tuned yar heating se taluq hai once car gets temp then it slows down
Tuning on cng? But i have recently changed spark plugs. It can be due to tappets clearence?? I have recently changed rings valve and their seals. 1. Before i changed bushes the sound was their mechanic advised me to bushes then the sound will vanish. But it is still their.
could be steering box any thing get it checked throughly
Can u tell me the valve clearence of mehran
Google f8b valave settings
Can any body tell me how to check the petrol average of mehran
Fill your patrol tank and drive 10 to12 km then refuel it.check the Quantity after refueling.
Hello pakwheelers. I have a query my mehran is giving me millage if 130 kms in city on 55l cng cylinder. Is it ok...
And ine more thing when i release clutch the tuck sound is produce and sterring and dashboard vibrates for that instant. Mechanic told me that it is due to the play in axles. Is it true? Thanx
No axels issue Its chimta issue May be one of shocks gutka is crakedIf ur axels are not leaking never touch them else u gona be in pain
If its with ac then okish Mine with ff tank gave me same milage in city
It is without ac what should be the normal millage for 55l cng cylinder
Both chimtas are replaced recently but issue is not solved. Btw what is shock gutka. And i t can be due to play khenchi?? If not then what are the symptoms of play in khenchi
Wht ever it is Not axels Some times foundations are also culprit
