Sir I just bought Euro 2 Mehran 2013. Its only 15k km driven. There is a problem in gear changing. As if I am changing gears without pressing clutch. What could be the reason?
Sent from my GT-N7100 using PW Forums mobile app
What happens when you change gears? Little more detail would be helpful? From your breif description i feel your clutch is down, get its operating positing lifted a bit by adjusting the screw of clutch cable...maybe it is not disengaging the engine from gear box even when fully pressed.
Thank you
New suzuki cars have that fault Even almost every new car made by suzuki That lever inside gearbox is in need if adjustment
Sent from my GT-I9300 using Tapatalk
What should be the point gap of mehran?
@ekdrifter iam uploading the pics of spark plugs of my mehran they are driven about 8 kms on petrol. Plz tell me the condition of plugs and also that why their are 2 colours at single spark plug .and what should be the expected millage on petrol. Thanx a lot bro
@ekdrifter
what is recommended bulb for front head light for mehran as my one fuses today
H4 halogen
Bro these u google them plugs color as I know only that if plugs have oil on them then valve seals and rings are done
Plz tell me the name of blue bulbs that u had in ur car. I also have these bulbs but iam not satisfied with their light.thanx
they cost 700rs and they are 1000W written on them box with relays light was near hid
145/70/12 ......... 155/70/12 ........... 165/70/12 .............. 175/70/12 ......... sub par meter par show hony wali. or real speed ak hi hogi,
For different tyre sizes on same gear box actual speed would be different for every size...for tyres with bigger dia it would be more....speedometers are caliberated to show real velocity at different angular velocities of tyre while keeping radius constant....
my point is that, wide hony se farq nai parta, height kam ziyada hony se farq parta hai
and one thing came in my mind when i notice is thermostat valve. My mechanic remove it in summer when he put new piston rings in the engine. should i put back the valve or not
Bro 145-70R12 would be smaller tyre compared to 155/165/175-70R12 in dia...as second number "70" in this case is dimensionless aspect ratio...For 145-70R12 tyre dia would be 12in + 2(145*70/100)/25.4in....Similarly calculate tyre dia for 155/165/175 replacing 145 with desired number for 12in rim....
if u check car tire size calculator 165 70 12 has more height then stock tires aspect ratio differs even with width
70 shows height, it height is not increasing then how it make the diff
For tyres, side wall height is not expressed in units of lenght, 70 in this case shows wall height as a percentage of tyres width....hope you get it...
