Looking for mehran shocks solution , replace both to stock? 2.Repair the right one which is hard on bump as compare to left one.Any specific brand recommended ? The left one is stock , right one isnt
Dear all. I have a question too, i smell petrol during driving when the driver side window is open, when ever all the windows r up there is no petrol smell. And my car is giving around 15kml so i guess average is good and there is no leak. What can b the issue
how u adjusted the carb mixture?
Oem Gabriel are best even better then KYB
The main fuel pipe which is of steel would be corroded thats why it leaks and till 1-1.5ltr leaks out then it stops. Replace the rubber breather pipe too.
Got this book dirt cheap yesterday (Haynes Data Book '90 Edition).These are some important torque specs for the Alto FX/ GLA.
AOA guys
I need to know best tuning place in Rawalpindi of Mehran Car Model 2008. or Any Special Mechanic Name? I Shall be thankful to you. Please guide me because consume too many Patrol.
Expected cost of oem shocks? Any jdm shocks can fit in?
There is a slight petrol smell always present in the cabin. I got it checked from a few mechanics, everything is fine according to them. Engine/carburettor is also well tuned. There is no leakage as far as i can tell. But the smell does not go away. Someone here mentioned about cleaning/replacing the breather pipe. Where is it located and what is it called in layman terms?
Front ones are around 5500-6000 for pair rear ones are 2500 but buy Gabriel because it is factory fitted in mehran. KYB is also available but not suitable for mehran. Don't go for used or refurbished shocks.
Thanks bro
Replace your fuel filter. It's cheap around 150rs. That should solve the issue
Okay, i will try this.
Em facing petrol back problem... Petrol dalty waqt bavk marti hy tanki
AOA, guys my car has an issue of fuel reduction on CNG. Its been a month that the car is with me and i have been running on CNG all this time except for night switch off and morning start. The car had slightly less than half tank fuel, since then the fuel gauge everyday shows very minut drop and now it has almost gone to E position.
mehran takes long self when the engine is hot on petrol. on cng it is f9. ihave sprayed carb spray in carb but no success plz help. thanks
Just open the fuel cap , if it sound like opening a pepsi bottle then its okOtherwise tight the ring attached to pipe of fuel tankSame was case with my mehran
Sent from my LG-F340K using PW Forums mobile app
KYB shock absorbers are very soft and they are really good. on the other hand gabriel are crap. they ruin your car body and your back bone as well. KYB are malaysia made while Gabriel are pak made.
plus fuel pump can be leaking. open the bonnet and check fuel pump. if you see any stains on pump or leakage signs then your fuel pump is going to go bad soon.
Sir mehran comes with Gabriel factory fitted. The KYB which people get in market is usually fake. Mostly kabari have KYB shocks, btw i'm talking about authentic Gabriel i didn't knew it was being made in Pakistan
